Old 02-16-2012, 01:57 AM
blykins blykins is offline
Originally Posted by Goopie 18 View Post
I removed my MSD distibutor from my Roush 427R. It came out easily. Now I cannot get it back in. It will not seat all the way because the distributor gear and oil pump gear do not mesh all the way. Do I have to turn the oil pump gear to "thread" it onto the camshaft gear? If so how do I do this? Do I have to start removing engine accessories etc. to get at the gear? Seemed like a simple job. Has turned into a nightmare.
You don't have to take anything off...it's a 5 second job.
Did you mark the position of the rotor and the distributor body when you pulled it out? If not, then you'll need to time the engine again and you'll need to be very careful about the way you install it....you can't just drop a distributor in, in any position.
If you did mark both items and it just won't drop down, then just start the distributor down in the hole, hold the rotor left of the position that it needs to be in, and walk it in.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
