Old 02-18-2002, 04:40 AM
Hank Dondero Hank Dondero is offline
Default Oil Pump
Suggest you check the type of oil pum and verify the bypass valve is operating properly.
I lost a dist. gear/cam shaft due to a high volume pump installed in a place where a standard should have been used. In addition, the bypass was very resistant. Checked a new pump out of the box and the bypass was frozen. HS!
I had steel gears and a roller cam.
Hank
FFR 111776-II
