  #37 (permalink)
Old 02-16-2012, 05:43 PM
blykins blykins is offline
Originally Posted by 347stroker View Post
I have a McLeod clutch in my SPF and it slips 3-4 and 4-5. the car has 27500 miles on it . Do you think its fried? I do know how to drive a stick because I got 1,003,000 mile out of the clutch in my Peterbilt.
Usually when a clutch is starting to go, it will start slipping in the higher gears like that. Will it slip if you leave it in 5th gear, load it at a low rpm, then get into the throttle?
If it's a regular organic/organic disc with a diaphragm plate, chances are that you probably have more engine than what the clutch can handle. Combinations like that are generally good for 300-350hp.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
