Thread: bypass hose
Old 02-16-2012, 08:21 PM
Pman1961 Pman1961 is offline
Cobra Make, Engine: Superformance SP02423 KCR 445W 611hp 599ft lbs
Panavia...What water pump did you use to do the arrangement you describe? I had KCR put an Edelbrock water pump with npt barbs so I could do as you suggest and have seen on another Cobra. The problem in my situation and the reason for this thred is the barbs are rotated ever so slightly clockwise from my stock water pump that the upper hose to the water pump would not slip onto the barb because conflict with the thermostat housing. I have the same aluminum spacer between the intake and thermostat housing as seen in this post. If you can could you post a picture? Thanks
