Old 02-17-2012, 02:45 PM
joyridin''s Avatar
joyridin' joyridin' is offline
Originally Posted by acoulson View Post
Thanks for all of the thoughts. That would be great if we could get a street beast forum. There is a set of knockoffs for sale on this site, but I'm not sure if they would work. They have a 5" backspace on the rear and are running a 315-35-17 rear, any thoughts?
Are you setting your car up for KO's?
As I mentioned above, to run this rear tire, you need to remove the coil spring perches on the frame and on the control arm. I had aftermarket upper and lower control arms on the rear. They were a bit narrower than the regular Mustang style. You would also have to run coilovers on the rear. It is a really tight fit, but can be done.
