Old 02-17-2012, 07:04 PM
patrickt patrickt is offline
Originally Posted by RestoCreations View Post
There is spark to the coil wire. There is no spark to the plugs,
If I am reading this right, and when you pull the coil wire out from the middle of the distributor cap and hold it close to the block and crank the engine and you see a spark, and then you plug it back in the cap and take a wire off a plug and do the same thing and see NO spark, then the problem is the rotor and or ball at the top of the distributor cap that touches the rotor. Replace the cap and rotor and bend the rotor prong up to make a nice contact on the little ball.
