Old 02-19-2012, 09:37 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
interesting these electronics. i was having difficulty with my gen 7 setup with noise and also a powerjection, and i had taken as many precautions as my mind would allow.
i believe the resistor is boosting the signal by allowing 12v into the signal wire, but does not allow it to flow back through the positive wire.
another note, if the magnets (if multiple) in the signal wheel are not oriented correctly or all in the same +/- pole orientation, it can confuse the ecu by a mixed signal i believe.
