Old 02-20-2012, 09:14 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I can help!
What do you want your car to do? If you want to go with true coil overs with your kit use the part numbers for a Fox Body Mustang on the rears (86 Mustang GT) and go with 340# springs. For the front use coil overs for a Mustang II with at least 400# springs SB and 550# springs BB. I installed a 1" front sway bar which made a huge difference. If your Cobra has not been upgraded from the stock B&B parts. Invest in some 2 piston Wilwood brakes for the fronts at least (using 15" wheels I think you can get 11" rotors in for sure).
"Let's roll"
"Be part of Something Good
