Old 02-20-2012, 10:33 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by 750hp View Post
I like the way you're taking your crankcase pressure out of the manifold valley, Mike.
My reasoning that there should be less oil mist in the valley than in the rocker covers. I also went with 2x #10 fittings since I haven't got any PCV connection pulling vacuum so needed plenty of airflow.
The other advantage of doing this is that it leaves the rocker covers completely uncluttered. Remove 4 bolts on each side and you are servicing the rocker gear.
Mike Murphy
Melbourne Australia
