Originally Posted by CHANMADD
The simple breather on the opposite cover works great . The initial reason to route the breather to the airfilter is to make sure that the air going into the crankcase is clean and filtered.
The air is sucked in the breather through the engine , out via the PCV and into the intake. In other words , as a seperate system , very simply in one side out the other making sure that what goes into the engine is clean. The PCV. Should definately be connected to the plenum and not a runner.
John
I thought most air cleaner PCV arrangements go INSIDE of the air filter element of the housing, not outside. I run a PCV off one cover to the base of the carb on the rear (which it was designed for) and run a breather on the other. My air cleaner housing has a boot covering the PCV inlet which is inside off the element (not filtered). You can see the PCV off to the left here going to the carb base and the breather on the upper right on the other valve cover.
