Old 02-22-2012, 03:56 PM
Seagull81's Avatar
Seagull81 Seagull81 is offline
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
All you need is the shroud to fit your radiator and fan. Is the radiator sealed at the top to make the air go thru the radiator instead of over it? What thermostat are you using? I believe 185* is correct for carb. How much timing are you running? Have you pulled a plug or two to look at the ceramic part for it to be a little tan? If they are really white, you are running too lean. I'm sure there are more folks with ideas that will chime in.
Steve
Texas Cobra Club-Seguin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
