Old 02-25-2012, 07:33 AM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Both ERA and SPF are great cars.
Only issue that you may run up against with an ERA is poor build quaility if the builder did not do it right. The first ERA I went to look at was an example of very poor build quality. It' looked like Stevie Wonder had built it.
The one in your link looks beautiful. Only thing to consider about it is how you plan to use it since it has a top loader 4 speed. No overdrive means it may be turning some higher rev's if you go on longer trips.
John Hall
