Old 02-26-2012, 08:36 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Looks like you did a great job with the modification.
When I was doing mine, I found out that the type of throw-out bearing can be one of two types. One that needs a small space between it and the clutch fingers and this is for a centered bearing.
The other is for a self-centering/self-aligning bearing and needs a little pre-load on the clutch fingers.
The self centering/pre-load bearing fails in not installed with the pre-load.
Arthur
