Originally Posted by Jerry Clayton
Do you have the spacers orientated correctly?? outside one should be the short one--the longer one goes inside the x member--if so, you may need to shorten the outside one a bit--thats what is meant by fabrication,, files, lots of files, grinders, hack saws-----
I have them backwards. I have the shorter one in the cross member because the longer one wouldn't fit. I imagine the cross member pinched down on the old control arm so I'll need to spread it back out to make the longer one fit. I see it now on the assembly drawing in the instructions. Thanks for bringing it to my attention! I feel like a dummy.
Hopefully it will go together easier once I swap them. If not I'll chuck the back side spacer up in the lathe and take a little off.
Thanks!
