Old 02-29-2012, 09:49 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
If you take into consideration that many of these cars have 600 hp and weigh aprox 2400 lbs, its easy to see that on a perfectly balanced 50/50 f/r weight that you have 1/2 hp per lb of weight on the tire----now what is harder to see is that if unbalanced, its not that a little hp transfers to the lite side , but most of the hp as soon as the wheel loses a little traction, all the hp goes up in smoke---
Complicate this into the braking situation---front rear bias, anti-dive, maybe some cornering---
It should become abundantly clear that corner weights being pretty close instead of just pretty is a necessity in a car like these
