  #54 (permalink)
Old 03-01-2012, 11:05 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
“Patrick restrained” LOL only in his fantasies. The appearance of restraint is actually the result of being caught with his hand in the cookie jar coupled with his inability to form a cognitive response. LOL
You should be careful when you pet the monkey! You own a Lonestar with a Windsor. That if far outside “double bubbles” tolerance capability. He will tolerate you, so long as you don’t challenge his self perceived superiority and are willing to accept his constant, unabashed ridicule for all Cobras not up to HIS standard.
With regards to your handling issue, I will be curious how the “corner weight gang” responds to this. I would doubt that CW is the cause. If the car doesn’t go straight under acceleration. Im not sure what you have for rear susp. But I would be looking at the rear axel first. Alignment, position, and pre-load.
Jason
