Old 03-02-2012, 07:11 AM
Dwight's Avatar
Dwight Dwight is offline
Smile B&B Cobra
A friend bought a 10 year old B&B with 351W and a T-5 Z last summer and brought it to me for repairs. He wanted new seat belts, shock, fuel sending unit, thrown out bearing replace. He wanted me to replace the brake fluid, anti-freeze, oil, tune up motor, adjust windshield wipers, padding in the seats, tighten steering,etc.
The motor smoked sometimes, turn out to be dry valve stem seals. Easy fix.
As I fixed or replaced thing I found a few other small problems. The worst was the front end. The upper control arms have bushings that had froze (rusted) to the arm. This allow the upper control arms to move forward and rearward about 1/2' inch. I replaced the bushing, I had to turn them down in size and added washers to keep them in place.
In my opinion the control arms need to be about an inch shorter. I understand this is a common problem with older B&B.
I have a friend in Ca. with an older B&B and he replaced his front end with the Heidts parts.
Heidts Heidts Hot Rod & Muscle Car Parts - Suspension Systems, Camaro, Chevy, Ford, Disc Brakes, Superide sell everything needed for about $600. With the wide front end you will have to buy rims with odd back spacing. If you have not bought the rims now is the time to correct that problem. Mike did not want to change them at this time so I fixed the problems with the bushing replacement.
After I got it ready and drove it Thanksgiving Day 150 miles for a shake down cruise Mike asked about the power. I told him I was not a dyno but felt like he had 280 - 300 at the wheels. He did not like the answer and I could not convince him to drive the car now and replace the motor later. He had me to buy a Keith Craft 408 with 530 hp & 540 tq. We also replaced the T-5 Z with a new 3550. New Classic Chamber pipes, ceramic coated the whole exhaust system, new radiator. We have a radiator factory in Alabama that made me a drop in aluminum radiator for $325.
I have put 350 miles on the car and next week Mike will pick it up.
This Cobra rides great, fantastic brakes, I never did get the parking brake to work. Older Mustang 8.8 rear end with 3:55 gears. Bad parking brake design is what I have heard.
This thing is fast. I have not put it to the floor test but I think this Cobra would do 11's at the strip. Oh yes, I put BFG Drag Radial on the rear, best money he spend!
Now I have to buy a pair for my Cobra.
This is the first time I have worked on a B&B and I am very impressed with it. This car ride great, has low end power, can cruise at 1400 rpms, handle good, soft smooth ride. Just a very impressive car. I think the tires size, trannie, rear end, motor all work very well together. I have driven 10 to 15 Cobra thru the years and this one has to be the best or close to the best I have driven.
Well, now Mike has what he wanted, a loud Cobra with lots of hp. A car he can take long trips in. He is going to drive it to Florida in the spring and to the London Cobra Show with us in June.
I have a couple of hundred pictures and several videos.
I had to keep Mike updated because I had his new toy for seven months. He retired Wed. and want to drive his Toy.
Enjoy your build, you have a lot of great parts to start with.
If you have any questions that I can help with just email me at algunruner@aol.com.
Dwight Frye
Florence, Al
