Old 03-03-2012, 07:25 AM
venum14's Avatar
venum14 venum14 is offline
Cobra Make, Engine: Bennett Cobra
ShelbyPower- As you mentioned the bearing change should be straight forward. A few thinks to investigate.
1. The bearing /retainer press fit area should only have two diameters. One for the fit of the bearing/retainer and a smaller diameter for the axle seal. The bearing and retainer should slide (no press fit) over the seal diameter.
2. Verify that the fillet radius on the axle, this is where the bearing diameter meets the larger diameter near the flange. The corner radius of the bearing must be larger than the fillet radius of the axle so the bearing face fully seats on the shoulder of the axle. Note, bearing quality varies greatly with many top names being made in China!
3. With calipers verify the inside diameter of the bearing and retainer. The ID of the bearing should be roughly .002" -.005" smaller than the axle diameter and the retainer will be .010" or more smaller. Only the retainer holds the bearing and axle in place, that is why there is such an interference. You don't want the axle coming out of the diff. housing when you go around a corner!
4. For installation, apply a small amount of Never Seize or bearing grease to the axle diameter and inside of the bearing, press it on first. Then apply the Never Seize to the retainer and press it on as well. It will take much more pressure to fully seat to the bearing.
Jeff
Jeff
