Old 03-03-2012, 10:06 AM
DAVID GAGNARD's Avatar
Gary:
I like to use the gray stuff,have had good luck with it....what I do is make sure the intake side of the head is clean,put the intake gasket on and make sure everything lines up correctly, then,when it all lines up correctly,remove the gasket, I "smear" some of the gray stuff around the water ports and LIGHTLY smear some around the intake ports, then install the intake gasket and press it all around,then let it set until the RTV is dry and install the intake manifold.....
The water ports need a little RTV for sealing purposes, the only reason I use a little and I mean very little around the intake ports is to hold the gasket in place when installing the intake itself..........I've never had a gasket move when installing the intake using this method......
David
DAVID GAGNARD
