Old 03-03-2012, 10:46 AM
ShelbyPower ShelbyPower is offline
Jerry - The axle retainer plate is a C-plate so it can go on after the bearings are pressed on. I am going to measure the axle OD and compare to the retainer ID. What should the difference be? Is the heat method generally OK--will I need much pressure to press on a heated retainer?
Jeff- Thanks for your info. I am still trying to figure out if I have a machining issue with the axle or if the retainer is out of tolerance.
