Old 02-19-2002, 05:54 AM
Greg Kulp Greg Kulp is offline
Bob,
Thanks for checking on this for me.
But now you've done it... you opened a new can of worms for me to consider. What are the components and part numbers you are using for the internal (hydraulic) throwout bearing setup? I'm curious what bellhousing, clutch, throwout bearing combination and assembly details you guys have put toegther to work well. Also, does the standard master clutch cylinder that comes with the kit work with the hydraulic throwout bearing setup you use?
Sorry for all the questions, but I may want to forgo the master/slave setup if you folks have an alternative setup worked out.
Thanks,
Greg
Greg
America. Home of the free, because of the brave.
