Old 03-04-2012, 09:06 AM
bobcowan's Avatar
bobcowan bobcowan is offline
You're probably best served with a rod end (heim joint) there. You will notice no difference in ride quality, and it will have zero bind. It will also probably be a little cheaper.
Do not use grade 8 bolt there. That's double shear there, and not compression. An 8 will fracture long before a 5 will.
You'll need to make some spacers out of heavy wall tubing to locate the joint and reduce the shear forces. Something like this, at the frame end of the arm.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
