Old 03-04-2012, 12:46 PM
Mac Osborne Mac Osborne is offline
Brad. I am pretty sure it use to be a double heim bar. You can see the end that failed has been cut off at the base of the old fitting and the metal circle was welded on to make room for some sort of rubber/plastic bushing. I just did a quick tape measure and it looks to be 10 -7/8 center to center. the bracket you can see is about 1.45 inside diam. with .51 openings (1/2). Other end has a heims with a lock nut.
