Old 03-06-2012, 12:26 PM
Ralphy's Avatar
Ralphy Ralphy is offline
Check the welds on the frame. Also see if the boxed tubes on the frame are cappped. Those were some chassis issues. Assembly of a SB is was the big issue. Many people had a hard time putting the kit together. The manufacture also was not very prudent in shipping all the kit as some say here. If you search Cobras on line, you will find a predominant un-assemebled kits to be SB's. The welded bracket you have on the frame is similar to what I have. The strut rod inboard should be inline with the LCA I believe.
There are so many versions and parts on the MII. Forged spindles, 2" drop spindles, LCA (true A arm), shortened control A arms, bagged, coilover, OEM spring. The MII is the most reproduced geometry out there. They are even putting them on GM chassis and others. MII rack as well.
Mustang II IFS front suspension, Hub to Hub IFS, tubular control arms, crossmembers
What?
