Old 03-06-2012, 02:27 PM
joyridin''s Avatar
joyridin' joyridin' is offline
They are not Pinto or Granada. They are M2. The original assembly manual was designed to take a M2 and bolt on all the parts. Whether the original strut rods will work with the lower control arms you have is another issue. Since most of these items were designed to interchange, the assumption would be they fit without a problem.
The set-up as far as how the brackets look are the same as was on my CMC. Most of the issues with mounts being out of location were directed toward the rear. I've never heard of anybody having a front end issue. For some reason, the rear upper control arm mounts were off location and caused a bind at certain angles on certain cars. The chassis wasn't as big of an issue as the body. Lots of twists in the fiberglass on the right rear.
