Old 03-06-2012, 03:39 PM
TimeForACobra TimeForACobra is offline
Cobra Make, Engine: Backdraft, Roush 427 SR/TW
Default Emergency / Parking Brake Adjustment
Hello...
Saw some threads but they are older, just want to double check the process.
My emergency / parking brake needs adjustment. There are a ton of washers on the adjustment on the brake lever. So, I need to go make the adjustment on the other end. The older threads mention pulling a wheel stud; however, my car was built in 2009 and has pin drive wheels. If I am reading everything correctly, the parking brake is inside the hub (not sure that is the right word), not on the caliper. So, if I pull one of the pins, it will provide me access to the adjustment star, right?
Thanks...
