Old 03-07-2012, 01:58 AM
blykins blykins is offline
I should be able to get one for you if you need one.
You'll be a little over 500hp I would think, so I would aim for a clutch kit that will hold that + 10%. McLeod and RAM both make 550hp capable clutch kits. If you want to lessen the possibility of chatter, I would go with the McLeod. The RAM probably won't, but it depends on your rear end gear and some other things, as it uses a sintered iron disc. Either one would work really well for you and I have a gazillion Cobra customers running each.
For the cam, either that you mentioned would work fine. If you're looking for something off the shelf (not a custom cam), the 282S would be my choice too. If you prefer a hydraulic cam, I would stick with something around 236/240° duration at .050".
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
