Old 03-08-2012, 04:57 PM
Towmaster's Avatar
Towmaster Towmaster is offline
Originally Posted by 750hp View Post
With the TR6060 and its nice tall overdrive, that will work very well with the 4.3:1 (if standard) rear ratio.
First gear will then make it nice and easy on the clutch to not have to slip it much while crawling along in traffic or through the pits.
That's right Craig, I did quite a bit of research on gearing before I decided to start. The Rodeo has quite a few different reatios depending on engine and drive ie 4x2 or 4x4. Diesel 4x4 ratio (4.3) makes it about 1750rpm @ 100 which is pretty good. It is a TR6060 tremec so the ratios are a bit different to the T56, really good down low in first gear and .57 in 6th.
