Old 03-10-2012, 02:18 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Where all friends here jim someone else might get some benifit out of reading this.....
Its a 69 Mach 1 290 Boss with 6 speed tremec going in it... Im going to leave everything on the dash standard.. The gauges... I shoud be able to swap the sender units out of the 351 into the 5.4 I will just need a couple of wires for Amp meter and the tacho...Im thinking I should be able to run nearly all of the original wiring..Just need to power the 290 Boss and thermos and fuel pump
Cheers Mark
