Old 03-11-2012, 08:30 AM
big deuce's Avatar
big deuce big deuce is offline
Originally Posted by Eljaro View Post
entdoc
exactly those two damn leaking gaskets at both sides of the banjo or fuel block can be replaced by the Stat-o-Seal gaskets. These are very similar to seals used in hidraulics, basically a metalic washer with an o-ring embeded in the inside. Works wonders!
I too an looking for the correct washers, but my fuel block is the one pictured. I like the small design of the Dowty seals, but not sure of what size. I also need the correct banjo bolts for this block. Any suggestions?
