Old 03-11-2012, 09:21 PM
whichonetodrive's Avatar
whichonetodrive whichonetodrive is offline
Cobra Make, Engine: # 238 lonestar w/IRS rear end
I found if you remove the screws from the visor's you can carefully use a razorblade at the holes and it came off easy, but I did soak them in hot water for 20 minutes first
Life starts when the little needle goes past 6,500 rpm's
