Old 03-12-2012, 06:33 PM
GBowman's Avatar
GBowman GBowman is offline
Cobra Make, Engine: BDR #1230/B2 445CI SBF
Jay-the distributor was hitting the intake, MSD makes one specifically for the Vic Jr intake which is a bit taller but exactly the same otherwise. It was not installed on my engine so I changed it. No good deed goes unpunished BTW I think my "bang is the trailing arm hitting the frame/body....if u look at it on the drive on lift, the front of the trailing arm is touching where the 2 bolts are. Do you think I can grind a little bit there?
Gary Bowman
Voorhees NJ/Key Largo Fla/Ventnor NJ
