Old 03-12-2012, 06:17 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default Don't Forget
Two things are also very important to making the pan gaske do its thing.
  1. Torque value: you need a constant - even force all the way around the pan. Make sure you use a torque wrench.
  2. Torque pattern: You need to tighten the bolts in a specific pattern so the applied loads are equally distributed. Look to an old shop manual and you'll see an "X" pattern is used. Follow it.
Over-torquing the bolts will distort the pan base. When that happens, you'll never get it to seal. Not torquing in a specified pattern will compress one area more than another and again, you'll never get it to seal.
Paul
www.65shlb.com
www.prdcrrct.com
