Old 03-14-2012, 04:47 PM
blue sky blue sky is offline
Hey Mark, The 2 3/8" centerline dimension is correct. Even though the handbrake lever is the same, the mounting bracket for a Mk1/2 and Mk3 are different. Use Nick's photos for what you want to do. The bottom bushing is threaded for a 5/16" countersunk screw which was where my problem has been at. You don't want that screw sticking through the mounting bracket otherwise it will interfere with the bias bar. Top bushing is a through bolt but I am going to insert that one also since I have to do the other one.
Nick, Is that your Mk2? If it is, I know what to get you for your birthday; a bottle of naval jelly!
AJ
