Old 03-15-2012, 04:08 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Wayne,
You are comparing a lifter full of oil to a new empty lifter, quite normal in comparison.
I would set your hydraulic roller at 1/4 turn past zero lash. The roller skids on the lobe if it comes off the lobe.
I would also consider a rev kit and a slightly lighter valve spring rather than the super heavy valve springs you have.
Gary
