Old 03-15-2012, 06:51 PM
ceslaw's Avatar
ceslaw ceslaw is offline
The "PowerGen" unit works well and provides a lot more amperage at low RPMs than any generatior will.
You will not have the tach drive off the back as the Lucas units had. The PowerGen has an internal regulator so the regulator on the firewall can be for "show" only making wiring easy.
Good points. Wiring the Power Master unit would certainly be easier. Hard to misfire a single wire.
Now I need to find a good picture of what the generator regulator originally used would have looked like. Would want to use a "dummy" unit for looks on the firewall.
