Old 03-17-2012, 03:29 PM
Merv and Sharon's Avatar
Merv and Sharon Merv and Sharon is offline
Greg, as you know I have the exact same system. When Peter was installing it, the main problem with my oval air cleaner was clearance at the rear and it is now off-set about 1cm to the front. Also the clearance I have between the distributor cap and the air cleaner is minimal.
However, your problem is height. My air cleaner lies entirely within the scoop and clears the front entry of the scoop easily. From your photos you could be OK with that aspect, if you can get the height down? Can the engine mounts not be lowered (apols., for the stupid question)? If you need me to do some measurements to match yours I could take off the air cleaner and check.
BTW - the motor looks terrific.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
