Old 02-19-2002, 08:08 PM
Jim Weatherall Jim Weatherall is offline
Block: '67 428 CJ
Heads: 428 Cobra Jet
Valve seats: hardened 5 angle grind
Valves: 2091660 REV stainless
Bore: 4.155 torque plate honed .005 piston to wall clearance
Pistons: J.E. #8043 4.150"
Cam bearings: FP33 Durabond Hi-perf
Rings: Speed Pro E243K+25
Crank: 1U (428 casting #) by Accu Crank in Arkansas
Rods: 428 Cobra Jet C7AE-B
resized to 2.5910 w/ ARP bolts
Timing chain: Rollmaster #TC-6
Cam: Crane 248/248 duration, .521" lift
lobe 602/602 108deg lobe center
Valve springs: Comp Cam 936-16
Valve spring retainers: Comp Cam 742-16
Rocker arm studs: custom U-stands for end supports
Lifters: Speed pro AT-2000 solid mechanical
Water pump: Edelbrock
Intake: Edelbrock Performer RPM
Valve covers: Cobra LeMans aluminum finned
Distributor: stock hei with lightened springs and centrifugal advance
Ignition wires: Holley 9mm Annihilator Laser Shot 50
Coil: MSD Blaster 2
Ignition module: MSD 6A
Carburetor: Holley 750 cfm, vacuum secondaries, worked to flow 830 cfm
Clutch: Centerforce dual friction
Air filter: K & N with full flow top
