Thread: Winter Storage
Old 03-23-2012, 06:43 AM
Dons427 Dons427 is offline
Cobra Make, Engine: ERA with a 428 FE that runs on pump gas, but has plenty of power.
I heard of a new way of thinking about winter storage due to todays unstable fuels.
The old adage of filling the tank may need re-thinking.
The reason for the full tank was the more gas in the tank, the less air.
Less air means less likely to build condensation, AKA water in the gas.
Todays blends have ethanol so its like the dry gas is already in it.
In fact if you add dry gas you will likely need a carb rebuild due to ruining the seals.
I heard that it is best to keep the tank about 1/8 full, but use stabil or sea foam on a full tank prior to running it low and storage.
Now; if the fuel begins to go bad, you can dilute the crap gas by filling it up with fresh gas.
Does this new idea make any sense?
Don
