Old 03-24-2012, 04:41 PM
strictlypersonl strictlypersonl is offline
If I interpret the picture correctly, the balance pivot moves from 2 o'clock to 8 o'clock as the handbrake handle is pulled. Because their is no length adjustment in the front cable, there are slots in the bracket so that it can be shifted slightly. It's sandwiched between the chassis and the driveshaft loop mounting bolts, so if you loosen the nuts on the bottom, you might be able to make the "access hole" larger.
