Old 03-24-2012, 05:03 PM
patrickt patrickt is offline
Originally Posted by strictlypersonl View Post
... so if you loosen the nuts on the bottom, you might be able to make the "access hole" larger.
Yeah, that might work. And if it doesn't, I'm just going back to my original plan of putting an access panel on the passenger side of the tunnel so that you just pull the passenger seat out, lift up a flap of carpet, unscrew the access panel, and poof the u-joint is right there in front of you.
