Old 03-24-2012, 07:46 PM
olddog olddog is offline
Shined a light down ports 2, 3, 6, & 7 and I can see the intake valves (Single plane intake). They are clean and dry. From where the injector sprays on is clean and directly under the injector still looks as polished as the day I installed the intake.
I rubbed my finger all around the intake. On the floor of the intake under where the PCV valve port is there is a hint of an oily film. The rest is a very thin layer of dry powdery carbon just like you would find in an exhaust manifold. I could rub it off.
I sprayed some carb cleaner on a rag and it wiped off. So I wiped the entire intake down until I had it clean. Then sprayed the cleaner directly on it and wiped it off with clean rags a couple times and it is just like the day I installed it again.
This intake has an air gap between the lifter gallery and the manifold. I don't think it gets hot enough to carbonize oil. Do you still think it is oil? I'm still thinking exhaust gasses sucking into the intake from the valve overlap, but it is everywhere. Even on the bottoms of the throttle plates. I wouldn't think reversion would go that far.
I'm interested in more opinions, as I'm not sure what it is.
