Thread: Panhard Bar
Old 03-27-2012, 05:18 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by Tim Brewer View Post
Joey, You HAVE to run a panhard bar, it's not an option, or a race only item. The panhard bar is what keeps your rear end from sliding out from under your car.
Like Tim said,the panhard bar is a required piece of a parallel 4-link suspension.
The axle has to be located laterally and the 4- links cannot do that except for a very minor degree.Without the bar there is no direct lateral restraint for the axle. A lateral force would put stress on the links themselves, and the joints at each end.
This movement will bind the suspension and will lead to failure of a link and/or the bushing/rod ends.
Bottom line....put it back on and enjoy better safer handling.
