Old 03-28-2012, 11:34 AM
PeteF's Avatar
PeteF PeteF is offline
Cobra Make, Engine: ERA2041 sold 2021
I am not knowledgeable on aluminum heads or cams, but is it possible that your valve lash is set too tight, and the valves are not fully closing when the engine gets hot ? Another thought is to check the choke fast idle screw to make sure it has not slipped off its cam, causing binding that won't let the throttle come to idle.
