Old 03-31-2012, 05:29 PM
TButtrick's Avatar
TButtrick TButtrick is offline
What "factory" did the engine come from? If your carb is "new to you" you should bench check all the static settings per Holley. Idle air mixture adjustment is normally associated with max vacuum but 1-1 1/4 turn out on each side will get you close. Check base timing first then check total timing.
