Old 04-01-2012, 12:45 PM
mybluecobra mybluecobra is offline
Cobra Make, Engine: Shelby 4000 series, 468 alum. Shelby
I have a Holley 950 ultra aluminum carb and it will fit in a Turkey pan.
You will have to widen the two fuel line openings in the bottom of the pan since
the Ultra Holley float bowls are larger, and therefore the distance between the two fuel lines is about 3/4 inch wider. You may also need to modify your fuel line setup for the increase in spacing between the front and rear float bowls.
