Old 04-02-2012, 10:27 AM
patrickt patrickt is offline
There must be some sort of miscommunication between you and Rick. The block plate does not affect how the starter engages the flywheel. The flywheel is still in the same place with or without a block plate and your starter bolts up evenly with the block -- so a block plate that's in between the two is not going to make a difference in the distance.
