Old 04-02-2012, 11:23 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
what is happening is the starter drive is coming out the hits the ring gear and gets stuck, but the motor never turns. the engine is just on the engine hoist i did not want to put in until the starter works. if i remove the starter the gear comes out and spins. the teeth dont look like they mesh right?.
i have a 184 tooth flywheel and there is 11 teeth on the starter gear?.
i hope it is not something stupid like not enough juice to spin the tight new engine, but the starter drive gear does not return so i know it is a mesh problem.
factory five mk III roadster, 445 fe stroker
