Old 04-02-2012, 11:29 AM
patrickt patrickt is offline
With the plugs out of the engine, a long socket wrench on the harmonic balancer bolt will turn the engine pretty easily. What you're saying is that when you crank it, the starter gear goes in between the flywheel gears, and then gets stuck, won't pull back in to the starter, and won't turn the flywheel either, right?
