  #21 (permalink)
Old 04-03-2012, 04:45 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
fwb, i have not reinstalled every thing yet to retry, rick the engine is not in the car i was running a mini starter with my small block i did have a solenoid on the fire wall if i remember i used it for a junction for the 12v cable and as a jumper for the ignition start wire?. the engine has been prelubed witha drill on several occasions, if you turn over your engine by hand to set the valves you will scrape off the lube. also the tech guy at cvr said they like to see 50 percent engagement with there starters?. once i put everything back on i will post.
factory five mk III roadster, 445 fe stroker
